Category 5
[quote author="dasbin"]Someone on another forum mentioned that bypassing the DC/DC converter in this mic will lead to a clearer sound. Any comments on this? And if you recommend it... well.... how do you go about doing this?
Thanks for putting up all this detailed info guys, I'm going to be modding my stereo pair with new caps soon!
Also I should note that I've had trouble in the past getting these mics open. The screws in the body are HELLISHLY tight on mine. Jewler's screwdrivers didn't give me enough torque so I tried some different slightly larger screwdrivers, which didn't catch and pretty much flattened the heads of the screws
Guess I'm drilling them out...[/quote]
My 603s dont have the screws, the body screws off itself after you remove the capsule.
If you have the older ones, or the mxl600 the screws in the body don;t work in the conventional way. To remove the bosy you turn the screws IN instead of out and then the sleeve slips off. to put it back on you line up the holes with the screws and back them out until they are tight. This is the opposite of how normal screws work.
Shane
Shane
