Marik
Brad,
Thank you for checking the trafo.
[quote author="lampas"][quote author="Marik"]Today I put into 603 a 6111 tube, wired as a direct coupled CF. The output trafo is a 1:10.5 Cinemag 2840, which is just the right size to fit the body. As I thought and said before, the capsule is actully very very good and I like the mic.[/quote]
Would you post schematic for it ? [/quote]
As I have said before, I still need to do some testing. I am struggling with the idea of having direct copuled CF and using 1:10 trafo, instead of getting signal straight from anode. They definitely sound different and I am still to deside which one to choose. In fact, I like the best "straight" CF with 1:10 trafo, but signal becomes way too low, bordering with unusable for many applications.
I guess, I should not mention things until I thoroughly test them out, but on the other hand, it probably gives ideas to folks, who like to try things themselves and deside what's good and what suits the best their applications...(???)
