thetraintomars
Member
Thanks for the help from the community converting my old MXR flanger to DC. I decided to take a crack at converting an MXR 118 analog delay from the same era to DC. This is the first generation with 1 output, a later revision had a second dedicated delay out line. I'm attaching an annotated schematic. The transformer/voltage regulator section convert the input voltage to an internal 12V, so I was planning to bypass all of that and just use the 12V output on my OneSpot power supply and connect power and ground after this part. I will also use a diode on the +12V input. Does that sound like it would work or is there a reason not to bypass the built in power regulator?
