spyder_hobo
Member
Sorry if it's a tired old subject but... I've got an old Pm1000 mixer and a TEAC 80-8 reel to reel lying around. I'd like to use the mixer as a front and back end for the R2R. Using 8 channels to track and 8 channels to mix. The main problem being; the mixer is +4db balanced while the R2R is -10db unbalanced. I've done a hefty amount of PM1000 reading and I think I have the solution, just wanted to run it by someone.
To add Direct outputs on the PM1000 tracking channels, I was going to tap off from C37, leaving it unbalanced. But, will the +4db still be an issue?
For the mixing channels I was going to add line inputs with a switching jack on the + secondary wire of the input transformer.
My concern is matching impedance, the output load of the TEAC is 10kohm unbalanced, and I've read that the board is looking for 600ohm, will this create any problems? Should I just build an 8 Channel DI box?
any advice would be greatly appreciated
