q2audio
Sorry Tillman, I didn't read all of your previous posts regarding modern replacements. Interesting that you have BC441 and 461 in place of the BC 413/415. The BC441/461 are rated at more Ic than the 2N3053/4037 but the 2N devices will work much of the time as a replacement, at least in my experience. Today, I replaced a 2N3053 and some SKxxxx device in a Neve BA438 op amp with the BC441/461 that belong in there. The 2N device had failed and was drawing a lot of current. I think the BC441 is rated at nearly 2A Ic, the 2N3053 is more like an amp.
I think that a discrete circuit is more fun than an op amp (well, more of a challenge) and will most likely have a more interesting clipping behavior. The op amp circuit is easier to layout and put together though. I'll bet that the modern equivalents of the BC413/415 will sound identical and the 40871/2 are just current amps, anything with similar ratings should work fine. The BC441/461 would be great if they were more readily available here in the US - Neve used them to do just what we are wanting and they rated them to drive a 50 ohm load, IIRC, in their BA440 op amp output stage. Come to think of it, a BA640 (IC version) would make a really simple solution to this problem. Easy to work with, you can get a bit of gain out of it if you want, and it will drive transformers all day - even if you short the output!
Thanks for posting the schemos!
