Delta Sigma said:Is audio still cutting in and out? What rate is it doing it at? Does it match the frequency your oscilloscope sees? Can you monitor your B+ at the power supply and see if it is changing (dropping) when audio cuts out?
I'm using 5840W, but also tried 6s6b-V.ln76d said:Hello Moshe,
i didn't read all your posts, so if you already tested mentioned below parts of the circuit, then just skip it
I'm not sure which tube you are using for your build.
I did disconnect C1 from the capsule side, but didn't set the selector to Omni, so I probably need to try that again. When I disconnected C1 I had less off that strange waveform.- try it with "true cardioid" only - if you used S2 for that purpose, then use it and just setup pattern selector to omni
Otherwise disconnect C1 from the front capsule side and set pattern switch also to omni
I don't have a spare capsule at this moment, but I put two 51pf caps instead of capsule for testing, to the same effect.- try to change capsule for any other and observe is there the same behavior or swap the capsules sides if you don't have any spare
I didn't understand what you mean by that. Anyway I swapped out C1 to another cap I had lying around.- check C1 at the first place in case of passive components
When I put a 10pf cap in series with the 8pf the problem got worse, when I put it in parallel it got a bit better.- for different substitute tubes there's worth to test C4 values from 3.3pF-10pF range
I will try that if it comes to that.- if anything from above list didn't help, then disconnect R3 from C5 as also C2 from R2 - then test again
lkipod said:Hey In76d!
I really appreciate you chiming in.
Thanks a lot!
Now I have something to do
Best Moshe
I didn't, just tried different tubes to see if the problem goes away.ln76d said:Why you resigned from 6S6B?
Polystyrene, 1000pf 600V, I thought at first that maybe I damaged it so I replaced it with polystyrene 250V that I had.Selector to omni is just to prevent applying voltage to the back diaphragm.
What kind of capacitor and what's it voltage rate - for C1?
Yes, capsule is brand new Thiersch red line.Great - i forgot to write about replacing capsule with capacitor and testing - if the behavior is the same then, i think we can exclude the capsule - last question about it - are the diaphragms clean?
OK, so that explains what I found.10pF and 8pF in series are ca. 4.5pF, paralleli 18pF (exluding capacitors tolerance here).
With lower value, you will get more gain so the "side effect" is just boosted and opposite with higher value.
C4 is silver mica (first 8pf, now 18pf) rated 300V, would you recommend switching to ceramic cap?What's voltage rating for your C4? If these are typicall ceramic capacitors with 50V ratings then maybe try some different with higher voltage rating.
I didn't had such issues with 5840, but some folks here had issues with oscilations using solid state replacements.
From what i remember it wasn't proper substitute to work with feedback which provides fixed HPF.
It's mentioned earlier whole node which starting from R3.
lkipod said:I didn't, just tried different tubes to see if the problem goes away.
Ok i will search for it and read up.
Thanks a million!
Moshe
lkipod said:I removed R3 and the problem is gone. ;D ;D
Delta Sigma said:I wonder if there was a problem with your 5M resistor or if maybe it has some oils from handling. Did you wear gloves? Next Mouser order, you should pick up another 5M resistor, maybe even a something bigger (for less feedback). You may not like the mic better with R3 back in but it's good to know.
Same with C4. Don't rip it out and be happy with no C4 vs C4 of 8pF. Try a few different values and record your results. I ended up deciding on 2pF then eventually removing it altogether. C6 is a low pass filter that can be reduced in value or removed. Many people remove C6 but I have mine in for now.
This is a very fun circuit to play with!
lkipod said:In76d, do you think I should switch the plate resistor to 200k? Now I'm getting voltage drop of around 68v witch should be ok, or did I get that wrong.
Delta Sigma said:Just in case ln76d doesn't chime in, 68V gives you 0.68mA. The Neumann schematics (M49b) show 0.73mA. Not only are you close to the schematic but you're very close to the 0.69mA that my M49b with 6S6B is biased at right now.
I believe the M49 version that used 200k had a different transformer which made a 200k load resistor make sense.
I am curious if ln76d has thoughts about a different load for the 6S6B or 5840. There are ways to keep the amp biased the same and change the load sort of like in a U47.
For my AC701 build I used the AMI BV11a (the very early transformer original used for the MSC2 tube) and for the 5840 I used the AMI BV11R (the one that was used for the C version).
HellfireStudios said:Neumann M49 is around ten thousand dollars these days. A TLM49 conversion at a fraction of the price sounds like a great deal for essentially the same mic.
Does anyone know of any similarly sized/shaped donor bodies for the D-M49 (hopefully cheaper than a Neumann)?
-James-
