TillM
This is the Schematic
https://cdn.groupbuilder.com/groupdiy/u/39511/58d1402a05456.pdf
TillM said:I don’t know why it don’t work with the Aputis body
Why don't you proceed with the classic Bv.11?Nele said:I'm organizing a group-buy for Cinemag transformers but will the CM-6511 be suitable for the 6V6S tube version or should I get a different one?
Moby said:Why don't you proceed with the classic Bv.11?
Replacement, yes, reproduction, no. I really don't want to judge about the quality of this transformer, but it doesn't match the original Bv.11 in many aspects.Nele said:Isn't the CM-6511 a reproduction/replacement for the BV11?
Spencerleehorton said:I’ll do a pic of the round connector as well!!
e.oelberg said:soooo.. I have this wonderful sounding, quiet (almost) m49c with 6s6b, BUT there is a low volume gsm audible, only on headphones and only with good quipment ……… it's annoying me ... any community tip ?
cheers, Nicholas
JMPGuitars said:Can a couple people please post their M49c voltages for each pattern?
My voltages change with each pattern, and performance is much different. Omni is much louder and sounds best. Cardiod sounds like it has a bass roll-off or something. F8 sounds lethargic.
In Omni my cathode is 1.65V and anode is 54V. If I switch to Cardioid or F8, K is 2V and A drops to around 33V.
Josh
Delta Sigma said:Mine is the B version so bias voltages will be different but you've got an issue there. Is your B+ changing as you change patterns?A change in bias may cause that much change in your anode voltage but I'm curious if you have current flowing somewhere in your pattern selection and capsule bias circuit.
It's possible you have an incorrect value component somewhere or a "short" in your hi-z section. Did you wear gloves and clean thoroughly when working on the hi-z components?
