RuudNL
Microphone is finished. Looks good, sounds great.
But now I need a swivel mount or shockmount, so that I can use it...
Ericbazaar said:Oliver Archuts M49 Schematic with RFT EF762 Tube.
e.oelberg said:could you maybe post the schematics ?
thanks, n
useme2305 said:i think he's refering to this schematic. beware of the error in the pin out labeling between pin5 and pin4.
trans4funks1 said:Hi,
Are there known dimensions for the three mounting holes in the base of the mic where the stack of circuit boards can attach?
Diameter of layout? Size of screw hole and threading?
Thank you.
flatresponse said:Hi Banzai,
not to put any pressure on the proceeding regarding the swivel mount.
But it would certainly be good, to have a solution from you.
Would make it easier without customs fee and expensive postage.
And maybe an attractive alternative to the Latch Lake ?
Thanks again, Banzai, for the phantastic mic bodies,
maybe you can chime in.
Regards
Manfred.
RuudNL said:Who knows what the thread in the holes holding the headbasket is? (M2.5?)
I want to use slightly longer screws.
