Neumann M49V tube mistery...
soapfoot
LA + Brooklyn
Klaus has said that he knows the tube type, and it's not a 6S6B. I'm not sure he'd have any incentive to mislead on that point.
For the record, I also inquired about his relationship with the project and Neumann/Sennheiser for the sake of transparency. He stated publicly in response that he had to return both review units and received no compensation other than the ability to order a new specimen at his usual dealer cost.
klausheyne
Member
What I don't understand, and maybe Mr. Heyne can explain it to me, why he wired the grid connection from the AC701 all they way down to the PCB pad and not directly to the insulated standoff right next to it?
Photo:© Klaus Heyne, 2022
Fair question. I wired it that way, for two reasons.
1. At worst, the extra length added to an already longer than usual ultra-high impedance path between the tube's grid wire and the stand-off post would have shown up in noise or artifacts. It did not.
2. But a direct connection between AC701 grid and stand-off post, completely eliminating even the current path length, may have influenced the comparison. To make sure, I did that, too, and again could not hear or measure a difference. So I decided to duplicate as much as possible the grid pathing in the M49V.
klausheyne
Member
Well, it could still be 6s6b-V. I am not concerned about his direct financial benefits from the Sennheiser/Neumann. There are others closely, very closely related tubes to 6s6b.
It was not any version of a 6S6B. I honestly do not know the tube in the final series.
vintagelove
Well, if some people know, it’s out there. Some folks just need to put their heads together and investigate. If anyone is interested, here is a catalog, triodes start on page 80. A few things will help narrow it down (I know you guys know this, but I mention it because it’s right at the top of each tube descriptio), filament voltage 6.3 and heater current 200ma to start. Feel free to add stuff we might look for... Sure would help if someone read Russian (so much for the Russian I took in high school).
k brown
California
My 2cents - a little too much obsession with the tube; as Decca found out decades ago, the transformer in the M49 and M50 has waaay more to do with the sound than the tube. When Decca replaced the tubes with a simple FET circuit, they found the change in sound insignificant.
So, the big question about these new '49s is, have they been able to come up with a transformer that can come anywhere near the big, big sound of the original?
Khron
Finland
What's so "sci-fi" or irreproducible about the original transformer, though? Surely they have all the core & winding data they'd need...
vintagelove
From KH review
"I was assured by Martin that the transformer is identical in its specifications to the original BV11."
kingkorg
Norway
I agree, so many good tubes out there. The only reason i'm interested is because the price of 6s6b, one of my favorites, might go balistic. But i just re-stocked at regular price, so whatever...
Purplenoise
It might not though, there are way more 6s6bś out there than ac701s and it seems 6s6b has a lot less rejection rate. Also the m49v looks like it will be produced in limited quantities ( which I think it’s part of the hype since it’s not really that hard for produce considering it’s pcb…the u67 or 87 are way more complicated to produce)
Moby
www.mobytransformers.com BV.8, Bv.11, Bv.12, T14/1
GDIY Supporter
Serbia
Probably the core alloy is not the same as the vintage Bv.11. So, generally speaking, ratio, inductance, DCR and capacitance can be "to the spec's", but it's hard to replicate the magnetics resistance of the alloy.
kingkorg
Norway
Probably worth to mention for the less experienced readers that some of these differences in performance of different components will be virtually inaudible, and easly adjusted with eq...
Noise and thd will probably be dominated by ambient noise, gear in the chain that follows...
-1db at 30hz, vs 10hz...
Mic placement and other basic stuff will be always more important.
Some of the differences might show up under extreme conditions in which these mics are rarely used. We are talking about 1% of differences, sometimes just educated guessing, theory.
granger.frederic
Interesting...
With the 6S6B-V, I noticed two issues : a bit too hot in a mic, and a bit too high grid current/leakage which drops the low end.
By the way, if the mistery M49V tube is as hot as the 6S6B-V, i wouldn't mount the cathode ecap as close as it is in the pre-version, for long term lifespan considerations.
Gus
n
The following is meant in a positive way IF the pictures in this thread are representative of the production units.
The microphone looks nice and I would assume sounds very good.
For the price I would think it would be detailed like a high end cars interior, exterior, air vent slots, tires, wheels, under the hood etc.
People will take pictures of the inside and post them on the web. If you look around the web you can find pictures of the interior of microphones.
Inside PCB picture
How the resistor leads are bent (cosmetic)
electro cap touching the tube(heat) others posted about this
Why does the grid wire attach at the PCB?
Flux on the PCB Is it "no clean flux"?
StackPath
