Hi guys,
don't know if this is the right place to ask but..... my fet 47 has a low output. 20db down from a tlm103 ( which is a very sensitive mic naturally).
i have just put together a fet 47 using the schematic and what i can make out from the layout provided here and.........
1. a RK7 capsule,
2. a peluso BV8PS xformer with the 11:1 and 5.5:1 option. ( which i bought of Sir POCTOP ). I'm using the 11:1 option of course.
The output seems kinda low. I'm sure the 10db pad is not engaged. The spec sheet for the fet 47 original says it has a sensitivity of 8mV/PA which should make it 10db quieter the a TLM 103 at 23mV/PA ( this mic i have for comparision ). However the output is 20db quieter than the TLM 103.
Is this correct? or is the problem likely to be.......
1) the xformer which at 11:1 is not quite right?
2) the 2n3819 is biased wrong or something. Should i add the 25k trimmer that you guys have and play with than in series with a 3.6k resistor?
3) the use of a polystyrene 2200pf cap? what effect would changing this have?
The sound of the microphone is ok. It's full range. Sounds good on a bass drum but sounds very 4-5K on the vocal and lacks a little bit of bass, maybe believe it or not. ( maybe thats the xformer. It's also very directional.
Is everything ok with this microphone?
Many thanks in advance for any help or pearls of real DIY MIC wisdom
Michael
oxford
england
1. a RK7 capsule,
Michael
oxford
england
