Scrappersa
- Joined
- Jul 17, 2011
- Messages
- 150
Those are all really good suggestions. I wonder if they would fit everything as well.
poctop said:Any chance will have to see some completed mic before the end of the world (21 dec-2012), ;D
just a toughts,
happy building still,
Dan,
Enchilada said:poctop said:Any chance will have to see some completed mic before the end of the world (21 dec-2012), ;D
just a toughts,
Dan,
I'll be using either an RK47 or a Dale M7, depending on which circuit I prefer. I'll have it done before too long though 8)
just a toughts,
Dan,
skidmorebay said:Hey all,
Having some trouble at first fire-up. Just getting a loud and steady low-frequency hum at the output. Everything appears to be assemble correctly, but obviously I need to look a little closer. What your first guess when getting nothing but ~60 cycle hum?
thanks!
JS
Testing with the body/headbasket off? That's the 1st guess
2nd: something isn't assembled correctly, bad joint, something touching the body that shouldn't etc.
skidmorebay said:Testing with the body/headbasket off? That's the 1st guess
Thanks, Pasarski. I was testing with the body off. I am brand new to microphones, and have some things to learn. I assumed that since I had continuity between pin 1 of the xlr to the GND pad on the PCB that I was OK, even with the body tube off.
The mic is working clearly and quietly now.
Pin 1 is connected to the mic body on the donor body I used (MXL 4000). Does the mic body do anything besides act as a shield when connected to Pin 1?
Another question for the group - I was unable to match transistors at home. Where in the circuit is it particularly important to match transistors and resistors? Any simple suggestions for matching the transistors?
thanks.
