Neumann U67 Clone : D-U67 Tube Microphone Build Thread.
If you really wanna pay that much just for that, sure, that'll fit, but...
But in case you'd like to pay 10 times less (and still be left over with a shell, that the 3-pin XLR insert your mic body may or may not have come with will fit)...
https://www.tme.eu/fi/en/details/fc6185/xlr-connectors/cliff/
Plus decent enough prices on other parts you might need(?)...
thanks a lot for the suggestion. never heard of that page!
The UPS (express) Saver can even get a package at least to Finland the next business day after ordering (if one places the order by noon or so) 👍🏻
Delivery time of 2-4 weeks, or..?
The last ones I ordered were on 27/7/24 and they were delivered 2/8/24, ~ 1 week.
I just ordered a couple more so we'll see if they're still on top of it.
I am in southern California so it's mostly just a trip across the Pacific so that might help. Other destinations may be more challenging.
eso
eso
And I ordered a couple more on 1/12/24 and they just arrived 10/12/24
eso
Putting my xmas Mouser order in and see there are 400Meg resistors in the BOM. Not in stock...any alternative value ok?
so i started assembling the PSU(230V) and am not 100% sure about the wiring/the measurements.
I get a correct voltage at b+ but only -0.4 V at H- ..... i have the FS20-300 Triad Transformer. I bridged 2 and three on the primary. do i have to bridge 6 and 7 on the secondary as well?
I'm thankful for every suggestion
Edit: So i bridged the secondary and now get 220V at B+ and at H- (-17.10) is that ok to proceed or do i need to get H- to -16VDC ?
So about mounting the moby bv12.... i have the regular pcb set and thought it would be nice to mount it to the ami t67 pcb. anyone else tried this, and are there any downsides/problems to expect this way? do i need to put an insulation between the transformer and the pcb?
View attachment 142117View attachment 142118
I ran into a similar issue when installing Cinemag transformers. after a lot of digging I arrived at this for the connections:
https://groupdiy.com/threads/neumann-u67-clone-d-u67-tube-microphone-build-thread.50021/post-1171032
eso
So i have some trouble with my build. As this is my first build of a tube mic i'm not sure how to troubleshoot acordingly so i hope somebody here is able to help out.
Problem: Output of mic is very, very low and also very thin. there is also some sort of high-pitch hiss.
The voltages -H and +B check out at -6.3 resp. 210v
I use a NOS brimar by mullard tube, a moby transformer and a beesneez capsule.
There are some mentions in this thread about bridging pin1 from the 3-pin XLR and pin3 from the 7-pin XLR. I have not done this as for now, would this get rid of the hiss?
Thank you for your help!
    5.5 MB
    3.1 MB
