The 60meg is floating so there are no pads or traces involved.
Last night I disassembled the mic **almost** entirely. I replaced the thick wires with nimble ones, I reheated **almost** every joint and bridge.Both ends? Can't imagine why...
What else could have fig8 working and cardioid and omni not!?
Yes, same thing is happening with both grill and tube off.Does the same behaviour happen with the grill and body tube off? Mic will hum like crazy but you should still be able to check front/rear audio.
Be careful.
I do get some signal in cardioid, but like 3% level of fig8. Omni is even less.Obviously (?) the fixed voltage applied to the backplate is missing. Front diaphragm is (more or less) at ground potential; without ~60V on the backplate, you'll get no signal in cardioid or omni.
In fig8, the rear diaphragm gets 120v, so even with the backplate floating, you might get SOME signal. May or may not be closer to a cardioid pattern though - I can't quite say which side the "front" of it might be, though. Or some wonky omni pattern, even? How's the side-rejection in fig8, by the way?
Any other measurements I could take? Everywhere I do continuity checks, I am getting solid beeps.
103V at the R13/15 junction and 47V on the C4 side of R13 and R12What voltage are you getting at the 2meg/3meg divider? "Before" that 60meg resistor going to the backplate...
49VStart at the junction between R12 and R13.
Beesneez K67. So to be clear, the wire goes on each side of R2?So far, so good. Can you solder a piece of wire in parallel with R2 (in essence, bypassing it), and see what voltage you can measure ON the capsule's backplate? What capsule were you using, by the way?
Beesneez K67
Yes, correct.So the two backplates are indeed in electrical contact, and only one wires is coming from them to the circuit, right?
Yes, correct.
3V on the backplate
With the wire bypassing R2, yes. I will solder it to the R12/13 node shortly.And is that with R2 bypassed with the wire, or not?
Come to think of it, it might be easier to just move where the backplate wire is soldered in the circuit, for this test... Ie. moving it from where it is now (one end of R2) to the R12/R13 node.
3.3V with the backplate connected directly to the R12/13 junctionWith the wire bypassing R2, yes. I will solder it to the R12/13 node shortly.
