- Joined
- Jul 15, 2009
- Messages
- 2,312
Deepdark said:Hi. Thanks matador. Yeah the L1 and L2 voltages are ok. So polarization is good. The only problem I get is that I'm supposed to get 40V at C5/FBK/RBK but at C5/FBK I only get 17V and RBK +/- 0.06V or so. The capsule and switch aren't installed yet. I calibrate drain of the fet to 11.5V, so what I think is maybe the problem should be around R13/15/16. That part of the circuit which inject voltages C6/R8/AA. I got 29V there. Maybe it's where the problem resid?
what transformer are you using ?, did you verify it if it is a T13. did you try the mic also ?. there is a lot of subtility regarding polarisation voltage measurment like Matador points out.
D.
