eastwinds
Member
- Joined
- Jul 25, 2013
- Messages
- 23
hi Fripholm
i finished one of these also. i had some problems with the low cut (should be pin 2 and 3) and pattern selector (should be pins 1,2 and 4) switches being wired the wrong way, so you may want to check that first. The M87 capsule appears to be a K67 design. you can do a continuity check across the backplates to make sure. it will work ok with this mic, you just won't be able to get fig8. i've been recording this week on this mic in cardiod mode, it sounds good to me. levels are about 10dB lower than a modern mic because this is a vintage circuit.
hope that helps
hope that helps
