Deepdark
Is that make a difference if I cut pin A (1) instead of pin C (3) as recommanded? If yes, why (personal knowledge)
Deepdark said:Nobody? Thanks giving has been hard for you folks ;D
Deepdark said:Yes I use those. Pin 2 is the ground and the other one goes to the fet. So cuting pin 1 or 3 on the pot doesn't change anything, the result will be the same as long as I keep 1 or 3 and pin 2?
Bull's eye!fsalter said:Thanks Udo
So just to be sure. Would this be alright ?
Will you please stop putting people under pressure?Deepdark said:Anyone?
mica said:Im trying to do the FET adjustment, and thought i understod it from reading these pages. (My first mic build)
The capsule is disconnected.
First i connected to R6 which i installed backwards as described (green wire) which i soldered to the center of the minijack. I attached the white wire to the ground og the minijackconnector at put the other end on the mic body:
Second i connected my mulimeter to first leg on the fet (from the edge og pcb) and to the drain connected to GG. Set the meter to V.
Then i opend logic and sent a 1ghz sine wave tone to output at 0DB:
I get a reading of aprox. 1.2 V. and adjusting R11 doesn't make a difference..
What am i missing?
