HellfireStudios
wtmnmf said:OK, I've checked out my two Peluso capsules and they are the same, but different from the above description.
The side with the lead on the rim's face is connected to the brass rim of the other side. The two brass rims are indeed isolated. Attaching the fourth lead as described above only duplicated the function of the existing lead.
So, does anyone know for sure if attaching to the other (opposite) rim connects to the other backplate? And is the capsule really asymmetrical? If so, which side is the front in light of the above?
I guess I'll try Peluso on monday if no one knows...![]()
If you don't attach both backplates to the PCB you will only get a cardoid polar response. Both backplates are integral to the pattern selection.
The front capsule is the one with both leads attached already.
FWIW, when I got my Peluso K87i capsule, it came with a tiny brass screw-down terminal. It also came with three screws (two for the mount, one for the additional backplate).
Attach a wire to the terminal. Attach the terminal to the side of the capsule (look at the capsule that came with the mic), not on the rim like the front backplate. You can use any of the holes in the back backplate, after you've mounted the capsule. Just poke a hole in the tape and use the remaining screw for the terminal. I hope this is clear enough.
