saxmonster
- Joined
- Jan 3, 2012
- Messages
- 534
Hahahah I see what I did. I'm an idiot. Details details details.
0dbfs said:Stocking up on parts for building four of these. I've now got AMI T13's in stock as well as Peluso's P-k87i's and of course four sets of Dany's PCB's. Just ordered four Aurycle kits.
I am planning to use a jumper in the mic to switch the patterns as needed and wire up the pad/hpf on the switches.
Next is the mouser order and I see that it is currently at what appears to be rev4. I'll review the parts included/specified and add in a couple parts for other projects
Looking forward to listening to more music through these!
Thanks Dany!
jonathan
Thanks Dany!
jonathan
poctop said:0dbfs said:Stocking up on parts for building four of these. I've now got AMI T13's in stock as well as Peluso's P-k87i's and of course four sets of Dany's PCB's. Just ordered four Aurycle kits.
Thanks Dany!
jonathan
For the BOM revision all i added from original is
All Cap option are in the BOM have a look to designation for the option
only the 10pf polystyrene is not in the Bom the default is the Mica
revisions
1) sub part for 2.2 in case not in stock for the vishay
2) sub for 60M for 68M
3) 2 extra Cap for testing and bypass 51pf
the best is to choose option in mouser in deleting what you dont need.
Hope this helps,
D ;D
berkleystudios said:poctop said:0dbfs said:Stocking up on parts for building four of these. I've now got AMI T13's in stock as well as Peluso's P-k87i's and of course four sets of Dany's PCB's. Just ordered four Aurycle kits.
Thanks Dany!
jonathan
revisions
Hope this helps,
D ;D
why is the 10pf not in the BOM? is that the only part i need to add?
You´re welcome.mrcase said:great! thx! just waiting for the capsules to try this out!
saxmonster said:The side with the two wires on it is the front side that is so you can tell the difference. Leave the tape on the capsule too. Once the capsule is on the holder you can poke a hole through the tape and screw in the wire for the back backplate. Also Cap = Membrane front and back side.
Incase anyone wants to know the over all price for this clone I spent $384.46 dollars on everything. Not bad at all compared to the actual cost of a U87, hahahahahah what is that about a 10th of the cost of a real u87? HAHHAHHAHAH Great project Dan Thanks again.
Any one try a different transformer yet compared to the cinemag? Any difference?
-Scott
wthrelfall said:great, but it doesn't explain the fact there's only 3 wires but 4 pads... what about the rear connections?
@Scott:wthrelfall said:great, but it doesn't explain the fact there's only 3 wires but 4 pads... what about the rear connections?
Marcocet said:wthrelfall said:great, but it doesn't explain the fact there's only 3 wires but 4 pads... what about the rear connections?
He did, but let me make it a little clearer.
Any condenser capsule has two major parts: The membrane and the backplate. When the membrane moves with changes in air pressure and the backplate stays still the difference between them creates an electrical signal that is analogous to the sound in the room. Many microphones have two membranes, one for the front and one for the back. This allows you to create varying polar patterns by blending the two signals.
The early U87 mics used a dual isolated backplate design. This means that each membrane has its own individual backplate. Hence the four pads on the pcb (front membrane, front backplate, rear membrane, rear backplate). The peluso capsules come with an easy solder tag along the rim to help you identify the front of the capsule. Connecting a wire to that tag will connect it to the front side backplate.
The fourth wire needs to be attached to the rear side backplate, which is electrically connected to the rear side of the rim of the microphone. If you'll notice, the capsule has three pairs of what looks like mounting holes around the outside of the rim. Two of them are spaced to hold the capsule to its mount, but the third ones are just there. You need to make an electrical connection between the one towards the rear of the capsule and the fourth pad on the PCB. I did it by putting a screw in to that hole and soldering a wire to it. It's as simple as that. A solder pad and shorter screw would have been more elegant, but the screws supplied with the capsule will work fine. Just keep in mind that the solder will not hold to the screw, so if you bang the mic around a lot it could eventually come loose.
If somebody else who has theirs handy could post some photos I'm sure they'd be appreciated.
