pavthefiddler said:
1. The boards don't quite fit the B2 Pro body (using the existing mount points). Has anyone come up with a tidy way to secure them and connect the PCB ground to the mic body?
Me again,
while waiting for capsules and trafos I worked a bit on this.
I widened up the mounting holes to 3mm (drill gently!).You´ll loose the ground connection at this point,but that´s no biggie:
You have several ground points on the pcb,just solder a wire to them and connect it to the mounting rail-done.
Oh-there´s an interesting thing about the rails:If your soldering iron gets hot enough you can directly solder that ground wire to the rails (worked fine on my build,I used a Weller WTCPS at 50 watts).
Or you can take a small eyelet and screw it to the rail using one of the existing screw holes.
Mounting the pcbs is easy then:Just use 2 screws (I took M2,5/16mm) and 2 nuts and washers.If you want you can secure the pcbs with a drop of 2k glue or so,but I don´t think it is needed at all after tightening the 2 screws well.
BTW:Mine is hammerite blue,hahaha.....
Udo.
See attached file please!
