fsalter said:Definitely the 7ma ones. The lower the Idss, the better. I have done a couple recently with 4ma.
fsalter said:Hi Jonathan
I'm sending you an excellent pictorial on how to bias with an oscilloscope.
Good luck
Fred
vinylwall said:Here are some pics of my build. Cinemag CM-13113 transformer, V-K87 Vintage Microphones Capsule, SYT-5 Type body from Mic & Mod, Neumann Purple Badge (hahaha).
Arkenberg said:Where might I ask did u find the badges? I really like them. You mic looks great!vinylwall said:Here are some pics of my build. Cinemag CM-13113 transformer, V-K87 Vintage Microphones Capsule, SYT-5 Type body from Mic & Mod, Neumann Purple Badge (hahaha).
Arkenberg said:Well guys I think I botched my build! Both mics worked yesterday but one had a bit of static that came and went like it was cycling, the other sounded perfect and had great tone. So I tryed to fix the one with static, I thought it was just the trimmer resistor I used and pushed over. I thought I had broken the inside. But after replacing it, it did not fix a thing. All voltages are good and the bias was set to 11.5 but it was really flaky and kept bouncing.
Now the other I think completely blew up! It worked great but I had to try and make it better. So I tryed the oscilloscope biasing method and for some reason I could not get my new oscilloscope to cooperate. I think it is broke or something, the probes would not even adjust properly. So I reset the bias via DMM at 11.5 and went and pluged it in. It gave me massive amounts of static and popping. So I unplugged and went to check the out come. Right now the voltage coming in is only 16v but when I unplug my phantom power it shows 48.7. I am really confused by this. Now my bias shows 1.8 and the voltage at the Zener diode is 1. something.
I did try and prove around to find a fault resistor or cap everything seemed healthy.
Any clues on these two problems guys?
In need of a lot of help, going crazy right now!!!!
Thanks in advance
Jonathon
Nope diode checked fine. What would cause it to cut the phantom power when pluged in?poctop said:Arkenberg said:Well guys I think I botched my build! Both mics worked yesterday but one had a bit of static that came and went like it was cycling, the other sounded perfect and had great tone. So I tryed to fix the one with static, I thought it was just the trimmer resistor I used and pushed over. I thought I had broken the inside. But after replacing it, it did not fix a thing. All voltages are good and the bias was set to 11.5 but it was really flaky and kept bouncing.
Thanks in advance
Jonathon
you must have busted the zener diode , probing arround, those are very sensitive ,
replace the zener diode and start from there ,.
Dan,
Arkenberg said:Nope diode checked fine. What would cause it to cut the phantom power when pluged in?poctop said:Arkenberg said:Well guys I think I botched my build! Both mics worked yesterday but one had a bit of static that came and went like it was cycling, the other sounded perfect and had great tone. So I tryed to fix the one with static, I thought it was just the trimmer resistor I used and pushed over. I thought I had broken the inside. But after replacing it, it did not fix a thing. All voltages are good and the bias was set to 11.5 but it was really flaky and kept bouncing.
Thanks in advance
Jonathon
Dan,
Also any idea on the static in the other mic?
Thanks again guys
Jonathon
Will try resoldering and get back with u on the out come.poctop said:Arkenberg said:Nope diode checked fine. What would cause it to cut the phantom power when pluged in?poctop said:Arkenberg said:Well guys I think I botched my build! Both mics worked yesterday but one had a bit of static that came and went like it was cycling, the other sounded perfect and had great tone. So I tryed to fix the one with static, I thought it was just the trimmer resistor I used and pushed over. I thought I had broken the inside. But after replacing it, it did not fix a thing. All voltages are good and the bias was set to 11.5 but it was really flaky and kept bouncing.
Thanks in advance
Jonathon
Dan,
Thanks again guys
Jonathon
cold solder![]()
