aclac said:HI. Just finished U87 clone and one question. I think, that my pattern polar doesn't work as it should. Can OMNI- position be about 8 dB weaker, than other positions? I mean, that when I make for example weak noise to front capsule, this is also weaker, and back side much weaker, when I turn around it and make same kind of noise... any suggestions?
CARDIOID and 8 working as they should, but OMNI has weaker output.
EDIT: I didn't get 60M (R4 and R5), they are 70M thick film resistor... can this effect something weard?
vinylwall said:I'm trying to wrap my head around hooking up a genuine Neumann U87Ai headbasket to Dany's D-87 PCB's. There are 7 connection points on the headbasket (which includes the capsule), but Dany's boards have 11 connection points with the switches and capsule.
Dany's PCBs:
PAD (2 wires)
PAT (3 wires) pattern
- OMN PAT 1
- CRD PAT 2
- 8 - PAT 3
LC (2 wires) low cut
RBK - Rear Backplate
RD - Rear Diaphragm
FBK - Front Backplate
FD - Front Diaphragm
Can someone help me make sense out of how to hook them up?
This is the portion of the U87Ai schematic that shows the headbasket connections (1-7).
If you think you might get serious about DIY I highly recommend you break down and buy a whole bunch of various values of polystyrenes from JustRadios.com.S-O said:The polystyrene are available on Dany's page.
If you flip the capsule leads around does the noise follow to the cardioid position or continue to just be in omni/figure 8? Basically try to rule out any potential capsule issue then work downwardOrganizedKonfusion said:Hey guys. I'm hoping someone can help me trouble shoot my mic. Cardioid works perfect, but Omni and Figure 8 have a bunch of overwhelming white noise. I'm assuming it might be a problem with the switch board or maybe part of the circuit that would be isolated to Omni and Figure 8. But obviously I'm a noob so I'm looking for advice on some troubleshooting I could do with my multimeter to help isolate my issue.
wave said:If you flip the capsule leads around does the noise follow to the cardioid position or continue to just be in omni/figure 8? Basically try to rule out any potential capsule issue then work downwardOrganizedKonfusion said:Hey guys. I'm hoping someone can help me trouble shoot my mic. Cardioid works perfect, but Omni and Figure 8 have a bunch of overwhelming white noise. I'm assuming it might be a problem with the switch board or maybe part of the circuit that would be isolated to Omni and Figure 8. But obviously I'm a noob so I'm looking for advice on some troubleshooting I could do with my multimeter to help isolate my issue.
-Dave
