micaddict
I have read a few comments that this build has low output/sensitivity.
More headroom than the U87Ai, though.
bnwitt said:Is there a schematic on the D87 which can be compared to the U87i?
bnwitt said:So no schematic I guess
fgan81 said:Hey,
I will order a package of SYT-5 clean Body's from ShuaiYin Electronics.
SORRY CHUNGER, they have lower Shipping costs for a German delivery.
Is someone out of Germany interested in dividing shipping costs?
Prices for each Body 3rd Generation like in Chungers Store would be priced as shown below:
Body 60,50 USD
Schockmount: 16,80 USD
Shipping (for 5 body's): 95,00 USD
Greatings....
ln76d said:aclac said:HI. Just finished U87 clone and one question. I think, that my pattern polar doesn't work as it should. Can OMNI- position be about 8 dB weaker, than other positions? I mean, that when I make for example weak noise to front capsule, this is also weaker, and back side much weaker, when I turn around it and make same kind of noise... any suggestions?
CARDIOID and 8 working as they should, but OMNI has weaker output.
EDIT: I didn't get 60M (R4 and R5), they are 70M thick film resistor... can this effect something weard?
Omni can be weaker. Did you tested it on your voice? If so, main difference is in proximity effect - which isn't present at omni.
70M resitors wouldn't affect anything, not with that small difference in resistance . If you would use at least 100M, you could only increase time of switching between patterns. Neumann use 68M.
bnwitt said:I have read a few comments that this build has low output/sensitivity. Have any of you builder found that to be the case?
