Paul678 said:Many people here were recommending the 2sk170 as a replacement FET for the 2N3819,
but Jim Williams considers this to be a "cloudy" sounding FET, and replaced it with the
faster J305. How about using the J305 in the Neumann U87 circuit? Has anyone tried this?
homero.leal said:Help, I finished a U87 build, and the mic has a problem.
Voltage at Drain, is always 23.2v. Adjustments to potentiometer have no effect on drain voltage. It just sits to 23.2v.
Most voltage readings look normal, with the exception of voltage at 10K resistor (after Zener). It reads 23.32. Voltage at zener is 23.45.
Also, if I check continuity between orange and yellow wires of transformer, DMM rings indicating 35ohm resistance on these two wires. Is this normal?
Thank you very much for you help, and best regards!
HL
micaddict said:
micaddict said:Samples are only samples, but I really liked what I heard from the Stam with the Sowter.
I preferred it over an original (vintage) Neumann
And I was not alone.
To my ears it has some U67 mojo.
