ln76d said:Still have problen to identify this issue.
Assuming that you have proper values of R17, R14, R12 i would try 33V zener instead 24V. I will look more later.
Neutrino said:Which values would correspond to the specs for the voltages I measured?
You said that my readings are odd. I'm just curious which values you would expect.ln76d said:Don't understand your question... Please be more specific![]()
Ok - two things which you can try - first use lower value of trimmer pot for FET bias - 12k-15k instead 25k. If this wouldn't help then try 33V zener instead 24V and set bias again. Note that original U87i (at least these revisions which i know) use 33V not 24V (which was borrowed from km84 circuit.
Neutrino said:You said that my readings are odd. I'm just curious which values you would expect.![]()
Neutrino said:OK, I will have to order these parts. In the meantime (for my understanding), would you mind explaining. a bit what it is that you are trying to achieve with the different trimmer and Zeners? To my understanding the value of the pot shouldn't really matter as long as it is set correctly.
ln76d said:For the trimmer i would suggest linear taper. Currently you have double value of what you really need. If you have logarithmic pot, then it is harder set it properly. Lower pot is just for more precise and easier setting.
Judging from your readings, you have higher current consumption than we should expect in this circuit. Making less voltage drop with the zener you should be able to bias properly FET in the correct range. Since we expect more voltage flowing around then more precise pot will be also usefullIf it will work, please write your readings in the same points as previously
ln76d said:In fact for U87 circuits which am building from the different donors, i prefer 33V zener (as in original U87 circuit) - it's really easier to set the bias in correct range.
Neutrino said:OK, I did some testing and here are the results.
First I thought I try replacing the jFET as you initially suggested. Originally, I had one with an IDSS of 6.43mA and I replaced it with one with IDSS of 7.64 mA. Biased again and no big change:
phantom voltage: 48.0V
-both sides of R14: 20,77 V and 23,31 V
-both sides of R2: 44,7 V and 44,1 V
-c9/c7 point: 8,68 V
-R19/R18 point: 47,5 V
Then I replaced the 24V Zener with a 33V one, biased and here is what I got:
phantom: 48.4V
-both sides of R14: 26.24V and 29.54
-both sides of R2: 44.5V and 45.1V
-c9/c7 point: 10.64
-R19/R18 point: 48.0V
So the Drain voltage is now in the expected range, although the other voltages are still on the low side.
I finally did not replace the trim pot since I felt the 25k one was not really problematic to finely tune (it is a multi-revolution trim pot).
What I found, however, is that the soundcard oscilloscope can be amiguous at times: Depending on how high I set the input level at the sound card input, I end up with drain voltages between 8V and 8.7V after the biasing procedure (that is for the 24V Zener). I have attached the final screenshot after biasing.
Neutrino said:My understanding is that when the FET opterates at a higher drain voltage that should increase the Dynamic Range, right?
Colorblind said:Looking to build a couple of these using Poctop's boards. The 10uf electrolytic cap is on backorder from Mouser until mid-December. Can anyone tell me if this will work as a substitute?
https://ca.mouser.com/ProductDetail/Vishay-Sprague/516D106M063JL6AE3/?qs=sGAEpiMZZMtZ1n0r9vR22fPWwtj8kO8a7hrPz8OzbVg%3d
ln76d said:Yes. More headroom.
Yes, it will be.
rockinrob86 said:What's your DMM?
It sounds like it's not accurate enough, unless you ordered 1% parts.
Colorblind said:The DMM is this one: https://www.cryptominer.ca/index.php/product/mastercraft-deluxe-digital-volt-meter/
The resistors are 1%. I just used the Mouser cart link/BOM that Poctop provided.
ln76d said:Then don't bother and use these resistors - it will work![]()
Ok, that's good to know.TillM said:Dan used to do it, that you can match them with a tolerance of 0,4%. (look also at the real Neumann u87 schematic)
For my first U87 build I don't do it. My second U87 has resistors that match.
I don't hear any difference or have performance problems.
