kante1603
@adeptusmajor:
Fet is biased,but the T13s didn't show up!
.... ;D ;D ;D
Udo.
Udo.
Yes The pin 1 is the closest to Screw,xqtion said:Hmm... tried swapping XLR 1 and 2. No luck. I'm still getting 10.5mV instead of 10.5V.
By the way which pin is pin 1 on the potentiometer ? Is the pin closest to the screw pin 1 ?
Yes,
Around what voltage should the drain measure without any resistor on R11 ?
Exactly what I think,having all 3 is a must-have for me.berkleystudios said:no filter though. not a major issue but still doesnt have all three selectors on it
Cool Dan,poctop said:2 More Little friend looking to mate transformer and capsule ;D
Still Waiting to try T13 and BV11
All Original : C7, C8, C10 Tantalum - C6, C1, C3, C15, C4, Polystyrene, I have been able to get some 10pf polyS from a Radio Guy just in town ;D,
Dan,
xqtion said:I've found something weird.
When I measure R18 and R19, I get 1.1k when it should be 2.2k.
Can this have something to do with my symptoms ?
xqtion said:I've found the problem.
The numbers on the PCB for XLR threw me off. I had literally connected 1 to 1, 2 to 2 and 3 to 3 of the XLR to the PCB.
But of course pin 1 of the XLR should of have connected to 3 ground and 2 to 1 hot and 3 to 2 cold. Duh...
Now I'm getting about 46.2V between zener and R18.
I'm running into one biasing problem though. The highest I can get the drain volt is 7.43V.
And potentiometer resistance is measuring about 26.5k.
Please help?
xqtion said:Yes pin 1 and the middle pin which is 2.
Also nothing connected to FC and RC.
xqtion said:Yes I'm getting 23.22V on the zener.
Thanks for your help~ Any more ideas?
Hi Hank,Hank Dussen said:Anyone knows where to buy these small toggle switches that they use for these mics?
