- Joined
- Jul 15, 2009
- Messages
- 2,311
This is Great Stuff Udo, just wandering if it would be even better to install it the other way arround , if you want to ultimately Bias with the pot in situ and leave the pot there you would have more room and angle to stick the screw driver in, i have question myself if i could also do the same with the original pot but i had enough room to do it this way so i kept going in this direction, the original pot is a tight fit but if you use a pair of small snipper to cut the edge gently or file a bit, it will slide in no problem as in this picture here, in my case the height was not the problem more like the contigueous width, it is just barely too wide on the edge to fit perfectly without a bit of snipping, this is an example on the Mxl body wich is the same as the aurycle.
i am not sure if the B2 Pro body is even smaller in diameter for the pot to go in , also i use to indent the pot from underneath to make some room for the Leg to go underneath so it does not require as much filing adjustment,
i wish i could have a mouser PN for your pot so i could add it in in case people prefer it.
thanks Again Udo for your ressourcefullness on this matter this is great contribution to this project and very appreciated,
cheers,
Dan,
cheers,
Dan,
