Ricardus
WILL SOLDER FOR FOOD
But an actual 2N3819 should have the proper pinout and be mounted as per the silk screening on Dany's PCBs?
Ricardus said:Looks good. What hardware did you use to fasten the PCBs to the rails on the mic body?
Duizels said:Thanks to the tireless help of Till I was able to build my U87 clone. Just plugged it in and it sounds sweet.
Unfortunately, the Peluso capsule I bought from Till got into the hands of my 1yo daughter.... well... it didn't end well...
So my current build is with a cheaper Chinese capsule.
Ricardus said:But an actual 2N3819 should have the proper pinout and be mounted as per the silk screening on Dany's PCBs?
Duizels said:Just the regular machine screws I think that came with the mic body. I purchased the mic body set from Pye at http://www.lifelongmusic.co.uk/
The transformer I strapped on with some tie wraps
