Hello everyone,
I am new here and just started building a u87 kit.
I have a few questions and if you guys could help, that would be awesome!
1. The BOM part numbers 538-22-28-4030 qty of 2 connector vertical 3 position // 538-22-28-4020 connector vertical 2 position qty of 4 // 151-8010-E Mini Jumper GF 6mm qty of 3; According to the information I have been able to find in this thread, I can see diyer's have made use of them on the PAD, OMN CRD and LC sections of the pcb. That equates to two 2 positions and one 3 position connectors. Where are the rest being used?? Also, why do we need the mini jumpers (151-8010-E)?? I don't see the use or need for them? Can someone please enlighten me here? loll
2. The second question I have is regarding "R11CAL" on pcb version 1.2 green tapered. There are two parts on the BOM...mouser p/n 72-T93YA-25K trimmer and 81-PV37X253C01B00 trimmer. I believe 81-PV37X253C01B00 trimmer is just meant as an option cause it's smaller? I intend to use the 72-T93YA-25K trimmer. Can you guys confirm this? So the next question regarding the trimmer is on the R11 pad section where am I inserting this part? As I understand it, on this particular board, I should insert the trimmer's three pins right in the middle so that I can see the two holes on either end of the trimmer? Also, from what I can see, the pcb is only using two pins on the pcb trace, correct? Can someone just verify which of the holes from the trace lines in R11 are actually doing something with the trimmer.
3. By now, its clear that the Fairchild 2N3819 is obsolete...loll. So it seems like the NTE-312 is the replacement. Has anyone experienced any problems when using this transistor?
4. Also, can anyone recommend a particular style or brand of hookup wire? I am trying to use the highest quality components on this mic and want to minimize the noise where ever possible.
5. When receiving my capsule, how would one go about checking the capsule for tuning?
6. I noticed guys testing their mic's and generating these really cool graphs! Where do I get my hands on that software so I can perform these tests as well?
Happy New Year everyone!
