Why not give it a try?Matador,do you think we must tweak anything around the fet then or simply swap and re-bias it?Matador said:The SK170 has the same pinout as the 2N3819 that's stock in the circuit: it's a drop in replacement (other than the rebias of course).
I would say do it.What's the situation with your capsule,have you received it?geekmacdaddy said:Go Udo! I have 1 spare 2SK170BL here, wondering if i should pull the 2N3819 and put it in....
Hi Dan,poctop said:Hi All, i am currently working on a u67 pcb but i am starting to wonder if i should have made a version of the u87ai as well question of having the DC-DC converter for the capsule as it will put out the same gain as the aI, just a tought :-\ ,
Cheers ,
Dan,
Any solution in getting more gain from the mic would be wonderful at the moment because it offers the use of way more "old"preamps with lower available gain therefore more "colours" soundwise.
poctop said:can i be in the brothers Club too, 8)
Hi Matador,Matador said:But higher gain means less headroom for loud sources...no free lunch here!
GREAT!Matador said:You bet: I finally got my Teflon standoffs so I can build two more mikes
...I'll try both FETs and see how much gain I can squeeze from each one.
