This is my first post here,
I'd like to thank poctop for making this project possible, and all the others who have contributed their valuable information.
I've built 5 of these sets using styrenes/tantalums and using the t13 transformer. I'm in Australia so the best i could seem to find
for a donor body with all 3 switches locally was the isk bm600 which i managed to get at a discount locally for 5. The pcb's fit the mic body comfortably
and the pcbs including the switches are easily modified to work in this project. The bm600 doesn't include a can for the transformer however as the original circuit has the transformer mounted on the pcb, but this seems to make little difference.
I'm now just trying to decide which capsules to use, i originally intended on the rk87, but after listening to Daves sample's am inclined toward Erics k87 capsules. My first real test will be on drum overheads and as room mics so if anyone has any feedback to offer on the different capsules it would be appreciated.
One thing i wanted to share is that i had a lot of trouble biasing the fet at the start.
I followed the instructions using the scope method, but every time i connected the oscilliscope to the drain of the fet and increased the signal level the sine would lean over into a sawtooth. I tried various methods for generating the tone, a couple of different sources for phantom power, as well as pc based oscilliscope using the output of the mic into an mbox2 which just showed clipping on the positive side of the wave regardless of the bias setting.
Also I noticed that with the scope there appeared to be much more level at the gate than the drain of the fet.
So after rechecking all my voltages, checking my transformer wiring, and looking at the schematic i tried again with the primary of the t13 disconnected.
Voila!!! The biasing worked as it was intended.
I referred to the instructions several times during my attempts at biasing, and didn't notice any notes about the transformer needing to be dissconnected, but please excuse my ingorance if its already stated.
I'm not sure if this is a problem with the cinemag but it definetely made scope biasing impossible with the t13.
Apart from that, i've tried one mic in cardoid mode with the stock capsule connected and it sounds very promising.
I can't wait to hear my final build.
HellfireStudios said:
Are the styrenes from the BOM polarized? I don't see any markings that indicate polarity. The tantalums/electrolytics are, but I haven't heard of polarized styrenes. If so, wouldn't the silkscreen indicate the positive or negative side for proper installation?
No styrenes aren't polarised, I believe only electrolytics including tantalums are.
Mick
