HellfireStudios said:Finally, here is the full on oscillation at any healthy volume level. BTW, the signal doesn't seem to clip. It just gets louder.
HellfireStudios said:top of L1 - 47.2v
top of L2 - 47.2v
top of R18 - 47.2v
top of R19 - 46.6v
bottom of R17 - 23.4v
top of R17 - 23.4v
Zener 23.4v
FET drain pad 6.7v
FET source pad 2.8v
top of R12 6.7v
top of R13 21.3v
top of R14 20.2v
top of R8 11.5v
Some of my readings don't seem to be right. Any suggestions as to what could be causing these unsettling problems?
mukole said:Hi Hellfire,
Your voltages on r8 and r13 are much lower than mine,
what are your voltages on r15 and r16?
Have you double checked the 2 electrolytics c11 and c13 are installed the right way around?
Also I'm guessing you may need to rotate your pot anticlockwise to increase the voltage depending which pins you
used on the pot.
cheers
top of L2 - 47.2v
top of R18 - 47.2v
top of R19 - 46.6v
top of R17 - 23.4v
Zener 23.4v
FET drain pad 6.7v
FET source pad 2.8v
top of R12 6.7v
top of R13 21.3v
top of R14 20.2v
top of R8 11.5v
Aaaaaaaaaahaaaaaaaaaahhhhh,sr1200 said:Hey i finally found out what happened to my mic! It wasn't a miracle from the gods afterall... seems i had the pad switch wired backwards... when i recorded with it last, i must have inadvertently switched it by accident. :-[ :-[ :-[ :-[
HellfireStudios said:None of my switches are hooked up. Just the transformer. Could my very low IDss FET be the culprit (3.8mA)? Thanks for your help so far.
kante1603 said:Hi Hellfire,
Even if you have other problems the biasing must be done accurate first.
Some questions to your procedure:
Is the capsule disconnected?
Where do you insert your test signal (sine)?
Is the transformer connected?
From which point do you pick up the signal to the scope?
Udo.
mukole said:As i couldn't get anything useful on the scope i set the voltage on the drain to 10.5v as dany suggested to do all my testing. This was pretty close to the final bias settings anyway. It wasn't until i disconnected the primary connections to the transformer that the scope started showing me anything useful.
Have you tried scoping without the transformer connected?
mukole said:You need to scope at the drain of the fet, once I disconnected the transformer I could see a much greater signal at the drain of the fet and the interference was no longer noticable on the scope.
I Hope this helps
