uffetuff said:Thanks Udo!
I already switched the output cables to fix the polarity issue. I just thought that maybe the problem is somewhere else. Maybe still at the transformer. But if it's just as good just changing the output wired I won't bother changing any more soldering connections.
The only thing I will add to it is switches for Pad and Low cut.
Ulf
wave said:I have experience with how the DU87 should sound when an RK-87 is installed. Can you post a sound sample?
Dave
uffetuff said:What are the sonic differences if I hook up the backplates in the wrong way?
pasarski said:No sound. I think your wiring is correct and the mic sounds healthy (and a bit unispiring to me, like a u87)
Looks like ~ -2db at 47hz compared to the CAD, not much. And the roll off under that doesn't matter really (if you're recording music with the mic that is). Looking at the U87 frequency plot, it starts to roll off at 60hz so that's also in line with your test results. Looking at your graph, CAD seems to be bit more scooped - broad dip at 2khz - that could also make it sound bassier.
Bass loss, if there really is some, could happen if there's flux or other dirt at the high Z area
craigmorris74 said:Hi guys,
Just recently started this project, and have all the components on the boards except my JFET and the resistor for bias. I'm trying the method described earlier in the thread to measure IDSS of the JFETs, but I'm not getting readings on my multimeters. I've tried 2 different ones, but no luck on either. Any ideas for what I could be doing wrong?
Craig
poctop said:craigmorris74 said:Hi guys,
Craig
How To measure FET Idss By Matador :http://db.tt/XEaPDHJ1
use a 10 ohm resistor and measure the voltage drop across to determine IDSS,
Dan,
