- Joined
- Jul 15, 2009
- Messages
- 2,312
HellfireStudios said:Well, I finally got my studio built, and have started tracking the local talent. I was tracking a female vocalist with the U-87 clone, and a problem arose. I'm getting a high-pitched whine off of the mic (seems to be around 12-13kHz). It also seems to swell in and out of the track (maybe a faulty capacitor?). Unfortunately, I was unable to discern this cricket-like and intermittent noise during tracking, and may be doing a free session or two to make up for the problem (EQ and noise reduction have been unsatisfactory tone-wise).
Other than an ungrounded polar pattern switch acting as an antenna, what else should I check out? I appreciate any help that can keep this from happening to someone else.
BTW, the mic sounds amazing otherwise. I'm using the Peluso K-87 capsule and BV8P-S transformer wired for 11:1. Styrenes and tantalums except for a couple of silver micas replacing the styrenes that were unavailable at the time. Fairchild 2N3849 FET biased with a oscilliscope. Full 48v phantom power from the included standalone P/S that comes with the Carvin CM-87S. I also added the polar pattern switch because the mic only had low cut and pad switches stock. Which is why I hope it is just the switch case leaking RFI into the circuit, but the sound swelling in and out sounds like a capacitor issue to me... Let me know, if I need to post an audio example. Thanks again.
-James-
I would probably un-functionnalize the mic First ,
if you can reproduce the problem with the shell open , then monitor the Drain Voltage.
the screeching noise and swell in-out , is probably caused that something that put the FeT out of a Job and it swings big time,
you could also inject sine tone in it , without the capsule to and confirm the hypothesis.
sounds like a capsule problem to me but can't be sure. , always then handy to have a testing kapsule even if it is a 67 then you can try the mic anywhay.
Always good to reverify the wire placement and also the intergrity of it when closing the mic body,
Hope this helps,
DAn,
