Arkestra
Member
To begin with, I'm not sure you can use these 1260's as mic pres but am trying.
I have read this thread:
http://groupdiy.com/index.php?topic=7126.20
and other posts referencing the 1272/BA283/31267 as a mic input. I am going into a B108 which looks very similar to the BA283. This drives a B104 in standard configuration
I am having an issue referenced in the thread above, there is a loud hiss, NOT hum, in all transformer configurations ONLY when a mic is plugged into the input. I have tried a Jensen JT-115k in place of the 31267 with the exact same result. I have wired the 31267's in almost every possible recommended configuration with no change in hiss. Pin 6 is grounded.
I am guessing this is either an impedance issue having something to do with the input xfrm loading (?) or a ground issue. I feel I have observed all proper grounding techniques I use in any other project. There is NO hum at 60/120 even with the amps wide open. With the mic attached there is still no hum but the hiss begins and increases as you adjust the B108 output (louder hiss with less attenuation) You can hear the signal but it seems for lack of a better term, "one legged"
I have rebuilt and bench tested all cards and am certain they are working properly. I am wondering if the B108 just does not have the gain for a mic, but I feel it should. On the bench I could "saturate" the B108 output with the 31267 wired up with a mic attached and monitoring through a scope terminated 50ohms.
Thoughts?
Thoughts?
