[quote author="promixe"]Martin, quick question for you:
Earlier you said you "safe-estimated" the current draw being 500mA per channel on the EZ1290 boards. It seems way way too much of a draw, since I think even the original 1073 with full EQ section draws about half of that (at most)... Would you say it would be safe enough to have 1A for 4 channels of EZ1290 in one chassis? I mean, we're not talking about absolute precautions here, just something that is "good enough" and is not gonna blow up in the next several years. =)
I'm thinking about using a single PSU2448 from Fivefish to power 4 channels of EZ1290s... Is it an absolute "no go"?
Thanks![/quote]
The problem is not the idle current (well not that it is ever truly 'idle' being Class A) but the inrush current.... 4 1073's can easily draw an amp on power up.... it doesn't hurt you to have a bigger supply, if the juice is needed, rather have it than not.. a stitch in time saves nine...
Matt
