mitsos said:Check the datasheet of the input trafo. You should have dual primaries. If you put them in series you have a 1:2 trafo, if in parallel, you have a 1:4 and lower input impedance.
Yes, correct.Whoops said:mitsos said:Check the datasheet of the input trafo. You should have dual primaries. If you put them in series you have a 1:2 trafo, if in parallel, you have a 1:4 and lower input impedance.
thanks mitsos,
I dont really know what its a 1:2 and a 1:4.
I know how to solder and build puzzles, thats how I'm slowly building this preamp.
but, from what I understood I can have a switch to exchange from a connection in series (1200 ohms) to the input transformer or to parallel one (300ohms) , is this correct?
the input trafo I'm using is the Carnhill 9045
zachs said:Whoops, are you not in the states? If you are, I can't see how that's possible, it was the easiest sourcing I've ever done.
trancedental said:http://www.flickr.com/photos/33553017@N08/3118994141/sizes/l/in/photostream/ BOM 1
http://www.flickr.com/photos/33553017@N08/3118994469/sizes/l/ BOM2 (resistors)
I've got a European BOM jpeg put together with all the manufacturers parts numbers from the original Digikey ect BOM
at the above links for the EZ1290, it's missing the following 6 items which I can't find @ farnell
rswww or Banzaieffects?????
c10 Polystyrene Digi-Key 399-4493-1-ND CAP 1500PF 50V 5% CER AXIAL KEMET
c11 Polystyrene Digi-Key 399-4480-1-ND CAP 680PF 50V 5% CER AXIAL KEMET
c3 Polystyrene Digi-Key 399-4511-1-ND CAP 4700PF 50V 5% CER AXIAL KEMET
c5 Polystyrene Digi-Key BC1045CT-ND CAP 330PF 50V CERAMIC C0G 5% VISHAY
C1 Polystyrene Digi-Key 1003PHCT-ND CAP 50V 180PF AXIAL CERAMIC C0G VISHAY
Phantom LED Digi-Key L10021-ND LED RED 1/4" HOLE 5V PANEL CML 5102H1-5V
Also the following resistor values seem to only be available in Carbon Comp / Metal Film @ banzai??
R10 Digi-Key 91QBK-ND 91 OHM 1/4W 5% CARBON FILM N/A ?
R6 Digi-Key 4.3KQBK-ND 4.3K OHM 1/4W 5% CARBON FILM N/A?
