Hi Eddie,
Great job!! I hope you'll enjoy the preamps for many recordings to come!
Miska: yes, V2.1line could be used a as a regular line input as well (no eq). I will only make V2.1line PCB's if there's sufficient demand, or if Bluzzi or someone else finishes the EZ1073EQ section. Most people just want a preamp.
Adam: pls see http://musiciansgig.com/ez1290/trimmer.pdf Please note that on the new V2.1 PCB's, the trace that is cut to accommodate the trimmer has been replaced with a jumper wire. This makes it far simpler to add a trimmer, or an EQ section for that matter.
All the best,
Martin
