I'm located in France.
I learned a lot about the differences between VR Legend i had taken care of before and VX, about the two automation's used in both ( FF and the VX had Encore), many things mechanical about the chassis ( we had to build some trolley to put the desk onto and given it was a 60 it needed some planing not to twist chassis), some electronic things... what you would expect from an expert.
Why i don't do it? Well because i know my own limits: i could recap everything audio related in chanels and master section, no issue i've already done it. It's time consuming, needs a bit of planing ( i prepared bags with capacitors needed for each section beforehand) but if you are focused and not disturbed will doing it, you have the 'good tools' ( expander which connect to main board and allow to check modules/chanels outside the chassis) then it usually run smooth.
But if there is issue within the automation or logic within the console i'm probably not able to identify the issues and fix them. This is where those consoles are complex. And i know too that a bad fix can generate even more troubles afterward and that sh.t happens even in routine servicing...
And there is the PSU. No way i put my hands into this. You are unlucky and have those 'coca-cola cans' discharging through yourself then...bye bye.
Or they releases their acid on you after exploding... no thanks, i leave it to those who knows, i've got two small kids and a wife.
It's exagerated of course but there is some really deadly things into the psu. The one for plasma bargraph scared me especially.
About the PSU i recently seen someone offered some newly designed ones, running cooler and with better efficiency than original ones, can be something to study given electricity cost and savings on AC in machine room. I will try to find the link and post it here in case you have interest into.
Edit: Found them
https://www.malcolmtoft.com/mpowersystems
https://www.atomicinstrument.com/shop/atomic-instrument-s1-5nty6-gcm32
So i would not comit to something i can't (fully) do. But if you want me to help doing safe soldering job under supervision of someone like Neil to take care of serious stuff i could really think about it!
In France i know some other guys which could do the serious stuff too. If you can't reach Neil then i could tell you with which to try but i'm sure there is other people able to do it in the place the console is located.
You are an musician that's it? Is your forum's avatar name linked to your musician's nickname Ray?
