alloitsjosh
Member
- Joined
- Apr 28, 2021
- Messages
- 15
Shuaiyin doesn't make those bodies, I can confirm.
How can you be so positive?Shuaiyin doesn't make those bodies, I can confirm.
We can't be sure at all but someone said me that is made by Shuai Yin, someone said you that is made by Alctron, if all the two says "No", someone is lying.How can you be so positive?
Chunger already deals with these people. I don't think they would sell to a non business partner
If you guys can lend me a u47 fet body, I could draw up some papers for it and we might be able to do this another way.
How are those style of bodies typically made? Cast, turned on a lathe, stamped, etc.
The problem is that the one I have is from a friend and I can't lend itIf you guys can lend me a u47 fet body, I could draw up some papers for it and we might be able to do this another way.
Turned from a solid piece? Isn't that ridiculously labor intensive and wasteful?most microphone bodies are turned from bar generally, though i'm not sure how this specific body is done
Starting with a brass pipe (thicker walled, if the body tube needs to be tapered) would make a lot more sense to me.
there is no way you could find out or order this body?I also deal with some of the same people. ShuaiYin, is a smaller org, mostly subcontracting out, as Soliloqueen said.
Same for me.LI think up to $200 or so shipped to US would be ok. I’d like one, maybe two.
I'm sure if you set up a white market thread you would sell out pretty quickly. It's worked for chunger.I suppose the MOQ will be the biggest problem.
Register today and take advantage of membership benefits.
