Biasrocks
In between ratio's would be cool, 1.5:1, 3:1, 8:1 would be a cool, useful addition.
Mark
Mark
Stagefright13 said:If using onboard xlrs etc. Then you would need a special case made such as Hairball did with Mnats 1176.
Stagefright13 said:Well I wouldn't want xlrs on the front. The Bargraph leds and switches on the front will easily fill a 1u panel. How do you space onboard XLR's to the back panel without a special case and slotted pcb lands?
John
ruckus328 said:-No cap lead bending, standard pitches on all parts.
-Redesigned on-board power supply. I was originally planning on doing an offboard supply, however as long as the main board doesn't start to grow too big, I'd prefer to keep it onboard (with a proper layout I can eliminate any noise issues)
mitsos said:While the HPF doesn't interest me much, most people I've seen posting "ultimate Gssls" have 2x HPFs, one on each sidechain. Just came to mind since you said the HPF would defeat the turbo, and maybe the HPF-ers wouldn't want that?
mitsos said:Re: cap lead pitch, when you say standard, some places in the world it's really hard to get wimas, panasonics, or whatever, and even between lytics: panasonics, nichicons, elnas etc, diameter/pitch varies quite a bit. Do you think maybe you'll put some 3-4 hole cap footprints to make cap selection a no-brainer?
mitsos said:re: case/onboard everything. bobschwenkler(sp?) made a 312 board that fit perfectly in the shallow parmetal cases (8 inches). Something like that might work here? and if you make front panels, people would only have to drill the back plate.
ruckus328 said:-I like the idea of having an additional range or two. If nothing else, a 1.5:1 would definitely be nice.
You the manruckus328 said:
- All that wiring
- it's gotta go! No more crimping. Ribbon cable interconnect between main and control board. Terminal block screw downs for other connections.
- Onboard XLR's option.
- Easy grounding scheme
- No cap lead bending, standard pitches on all parts.
- Improved solder pads for much easier soldering
- Detailed & Up To Date BOM
- True Bypass feature
- Integrated Turbo Board (Switchable)
- Both the bypass and Turbo switches will have provisions for use with illuminated switches if desired
- DBX202 Support
- Sidechain HPF (If present) will automatically enable when turbo is switched off. Unless you guys feel strongly otherwise, I'm not planning on integrating the sidechain circuitry into the desin since turbo seems to be the preferred option, but full provisions will be included for attaching the sidechain board. It would be nice to have this too but I feel the line should be drawn somewhere.
- Redesigned on
- board power supply. I was originally planning on doing an offboard supply, however as long as the main board doesn't start to grow too big, I'd prefer to keep it onboard (with a proper layout I can eliminate any noise issues)
- Onboard Pots
- Bargraph meter (Onboard). Switchable between GR/Input/Ouput. Detachable and bypassable for use with a Sifam style meter if you choose instead.
- I like the idea of having an additional range or two. If nothing else, a 1.5:1 would definitely be nice.
- Detailed Mechanical drawing templates for mounting / connector holes.
tommypiper said:Don't care for LED metering etc. I want a VU METER!! Can we still use a real VU meter?
tommypiper said:I felt the Gyraf PSU was crap, (with all due respect, I'm sure its design goals were met, it works, etc). I would like a possibility at least to do my own off board PSU or enough space to make mods on board, parallel caps, etc. Please use 3x7 regulator, or whatever the exact one is/are, not the Gyraf regulators please.
What issue made you decide to create an onboard PSU? BTW, as far as I understood form another board member, dagoose, probably the best way is to use an offboard PSU with 317/337 regulators.ruckus328 said:Well, definitely no disrespect to Gyraf, without him none of what I'm doing would be possible. As you said, yes, it works - but there is definitely room for imrpovement in this department. I'm leaning more towards an off-board PSU, but rest assured - I layout HV/Power supplies for a living, so the PSU will be a premo design, not cutting any corners here.
ruckus328 said:tomcat said:and maybe a LED meter option. The sifam 14 are discontinued, so....
Good idea. Those Sifam meters are rather pricey to begin with anyways imo. Only thing is, this is something I haven't familiarized myself with yet. Are there any changes that need to be made to the board in order to work with an LED meter? Isn't there a LED meter board designed somewhere here on the board? Are you just talking about being able to use it with my layout? - Or for me to do a new meter layout also? Can someone point me to where I can get some info on what's already been done in that respect?
snipsnip said:if you do a run of front panels can we try and get some concencus on the colour scheme? I have a real dislike for black with white lettering
