Igor said:The pin diameter of 202 (measured) is 1.1mm. 1.3mm (0.086') drill shoild be fine.
The 12V’s are used in the board as subregulators for obtaining predictable gains in case the main (+-15V) supply fluctuates.
The GSSL sidechain VCA used to be implemented as DBX2150. This Chip has a recomended supply voltage of +/-12V or 24V across IC and absolute max.30V across IC. Tolerances in 7815/7915 voltage regulators might exceed this VCA abs.max. voltage rating. With THAT218x you could supply it with +/-15V, adjust the Ibias resistor value, connected to VCA pin5 for required current and recalculate the ratio setting network for the added DC-offset. Adjusting threshold and makeup for extended range shouldn't be a big deal.ruckus328 said:Guys, I have another question. I'm curious - does anyone know the reason that Gyraf chose to run the sidechain off 12V instead of justy running it directly off of the 15V rail? Has anyone done any experimenting with running it directly off 15V? I know the IC's (THAT/TL074's/etc) will run fine at 15V, I don't know if there's some catch I'm not seeing though. I mean, there has to be a reason he did this right?
Harpo said:The GSSL sidechain VCA used to be implemented as DBX2150. This Chip has a recomended supply voltage of +/-12V or 24V across IC and absolute max.30V across IC. Tolerances in 7815/7915 voltage regulators might exceed this VCA abs.max. voltage rating. With THAT218x you could supply it with +/-15V, adjust the Ibias resistor value, connected to VCA pin5 for required current and recalculate the ratio setting network for the added DC-offset. Adjusting threshold and makeup for extended range shouldn't be a big deal.ruckus328 said:Guys, I have another question. I'm curious - does anyone know the reason that Gyraf chose to run the sidechain off 12V instead of justy running it directly off of the 15V rail? Has anyone done any experimenting with running it directly off 15V? I know the IC's (THAT/TL074's/etc) will run fine at 15V, I don't know if there's some catch I'm not seeing though. I mean, there has to be a reason he did this right?
livingnote said:Well if you're going separate supply for "rough stuff" like relay and LED power anyway, what I just did was to
cascade some 12V regs right off the 15V audio rails - works really nice, I guess without the power on LED
dangling off the little regs you could just as well power the turbo circuit+sc right off the 78L and still have room
to spare.
tv said:you're loading down the main "audio-rails" regulators this way. not wise at all. this is not a "true seperate rail" for leds.
if you want to "decouple" the "leds" rails from the rest of the circuit, do it exactly like gyraf did it (BEFORE the regulators, i.e. directly from the graetz bridge). perhaps try to increase the in-line resistor to reduce the regulator heat dissipation. Personally, I would use lower voltage than 12V to power the leds.. but this is not my project.
Additionally, take care that ground current return paths from LEDS on the PCB don't mess with the "clean" audio ground..
>>> I'm confused by his statement that they're there to provide predictable gains in case the 15V rail fluctuates?
There is absolutely nothing confusing in this statement.
Why dirty ground at all? Powering relais and LEDs from a floating maybe 24V regulator across bridge rectifier with regulator both sides input/com voltage dropping/heat sharing resistors in front should keep 0V clean and keep any hash in front of the audio rail regulators.tv said:I don't think you would need a full bridge for powering the LED rail, since it is a single rail, in this case two 1N4007's would do.
The C-R-C filtering is cheap and works bi-directionally (you can "look" thru it both ways, from the brige towards a regulator and from the regulator to the bridge, backwards) so it will decouple any surges/hash happening on the LED rail from other rails (adding a resistor could work as a "bridge" in single sided PCBs).
I would advise that you make a separate "ground" rail for the "dirty" return currents from the LED rail. If you must reference control voltages from sidechain etc, you can use "ground sensing" (with an opamp/diff-amp) to decouple the clean "audio" ground from this "dirty" LED ground, where the two would otherwise need a hard link.
Sure, but I was thinking the floating supply. The usual LED metering suspects LM391x don't seem to have differential inputs and the chip internal diode at signal input buffer pin5, V- pin2 and RLO pin4 seem to connect to the same potential, usually gnd. This supply then would not be floating anymore and LED currents get dumped to audio gnd again.tv said:>>> Might get tricky with circuits referencing audio gnd
Not at all! In a "GSSL" compressor, you have negative CV, so for the GR meters etc you would need to invert it - which is an ideal place for "ground sensing" the "clean" ground via the noninverting input of the opamp that "processes" the CV to be used in the LED meter...
