Hi all
So I started with schematics down here, to kicad, to this gerber
Untested yet but the boards turned out great from JLCPCB
Only mistake is the mounting holes are approx 1mm too close to each other, so I have to very lightly bend the mounting rails for the holes to line up. The body can still be assembled without problem.
I offer no guarantee, no help with the build etc. It is pretty much 1:1 the orig schematic and there are plenty of info around.
In case you don't want to use them L1 and L2 must be replaced by a straight wire, and C21 and C22 omitted.
Rename the TXT to ZIP to get the gerber
High Z teflon pins are meant to be Mouser no 534-11218
There are different options for C7, orig is tant but some like to mount bigger caps.
I am slowly starting to build a cardiod only pair of these, I'll report back... If someone else goes first, let me/us know
I'll use a pair of UTM transformers and I'd like to use a pair of Arienne's cardiod K87 capsules when available
