I did some quick and dirty measurements last night. I've got some screenshots of the spectrum plots from the plugin I used, but I'm stuck behind a firewall here at work and can't get them to link properly. I can post them later on this evening from home if you like.
Long and the short of it was I was seeing about -58dB noise in both the left and right channels with all the controls set fully CCW, except for the gain makeup control which was set all the way up (+20dB). Stereo Link was on, Bypass In, Comp and Limit for each channel In, Limit set to Fast. Nothing connected to the inputs. Soundcard interface set to 0dB (Presonus FP10). I doubt that the results I got were completely scientifically accurate, but they should give you some indication of what I'm seeing in my unit. With the unit set to a more respectable makeup gain level the noise disappears into the background.
Page two of the test procedure suggests that the nominal noise figure you can get is better than -75dB with the makeup control set to minimum, and -55dB with the makeup gain all the way up, so I guess the figures I'm getting are pretty much the same as the original (assuming my test method is OK).
Edit: just re-read some of your earlier posts - I didn't know RMAA was free, I'll download it tonight and retest my 33609 using it so you can compare the results properly.
Just had a quick look at the Neve website. They quote their 33609JD (their modern repro) as having -55dB noise figure with the gain makeup control at +20dB, so maybe this is as good as it gets?
