nielsk
Strapped a resistor across the meter terminals, got adjustment range.....2k seems about the best
Has anyone else had to do this?
promixe said:Some audio examples:
Can some one run the unprocessed file through their unit AND/OR the original 33609(C/J/JD)?
Original: http://dev.ax-design.com/electronics/33609/33609-test4a.mp3
Compressor IN (THD -4dBu / 100ms RECOVERY / +6 GAIN / 4:1 RATIO): http://dev.ax-design.com/electronics/33609/33609-test4b.mp3 - the 100ms problem was fixed by replacing R10 with 24k
Limiter IN (THD +4dBu / 100ms RECOVERY / FAST attack): http://dev.ax-design.com/electronics/33609/33609-test4c.mp3 - you can hear the distortion. I don't know what it would be attributed to (see next link)
Limiter IN + Compressor IN (setting are as above): http://dev.ax-design.com/electronics/33609/33609-test4d.mp3 - really distorted signal. Compressor smoothes the track, adds gain makeup, and then the limiter freaks out. It sounds like there is an overload somewhere along the limiter sidechain. Where would I look? It calibrated fine though...
Examples C & D sound pretty horrible if you ask me =)
Example B on the other hand really remind me of the classic neve-ish mixing desk sound. That one gives me hope =)
I would really appreciate if someone replicated same settings on their unit (DIY or original) and posted audio. I can provide space for it on my server if needed. Thanks!
maxheadroom said:hello promixe,
have you found a solution regarding your problem with the distortion of the limiter?
i have the same problem. especially on limiting the bass as single signal i hear great distortion when i turn the limiter on.
anyone else have this problem?
Curtis said:That's the same one I used. You'll need to print a new scale for it and stick it over the front of the VU scale, and also fit some shunt resistance across the meter terminals to make it work properly (as was mentioned a couple of posts up).
I could mail you the scale I used if you like, although some of the gain reduction markings were a little off.
ultra-alex said:in search of the threshold switches i just talked to elma germany and the told me that the elma 04-1130-20 is NOT in production anymore.
substitute is ELMA 04-1133-20. don´t know if this has already been mentioned before...
cheers, alex
nielsk said:Same distortion on low end here, lots in limiting. Could this have something to do with using the 340 instead of the 640 that the actual 33609 uses?
Has anyone tried one of these with a 640 in it?
I will try to find some time to compare the 2264 (it uses the 340) and the 33609 schematics and try to find any other differences that could contribute.
nielsk said:Same distortion on low end here, lots in limiting..
PS: already 3 people in the "low end distortion camp" - even better =)
