Gachet
Hello
How do you guys wire the CT12?
The two pins on the side of the capsule goes to center?
gyraf said:..honestly, audio examples tells you absolutely nothing when it comes to microphones - UNLESS you set it up yourself, so you know exactly how the room/position/performance was..
..yes, I know there are companies claiming otherwise, but it seems massively unconvincing to me..
/Jakob E.
Joekkel said:Hi there
I recently finished two Gryaf G7 mics with interchangeable headbaskets/capsules. For bodyparts/headbasket i used 4x this mic: https://www.musicstore.com/de_CH/CHF/Fame-Audio-Studio-CM1/art-REC0004714-000
Had to cut the pcb to fit the diameter of the body (stainless steel tube bought on ebay). A XLR conector is mounted to the interchangeable headbaskets, i even didn't need to drill new holes, as the holes in the m
lampas said:What the great idea to make interchangeable capsules !!!! Need to listen samples too !!!
