I'm not sure - I hope so! But what would a suitable transformer be? I'm just following the
components list on Gyraf's site (and I don't really know what I'm doing).
I don't want to question the proven design of Jacobs G7 but the back to back solution (which definitely works) has some disadvantages and was probably due to the supply situation for such transformers at the time.
A dedicated tube transformer brings some advantages, the schematic says that you need 135VAC and 9VAC at least on the secondary side. The 135V rail must be able to supply one(!) EF86 with one or two mA, the DC heater voltage according to the data sheet for the EF86 must be able to supply 200mA.
You need such a transformer or similar (means with larger values), which you then make suitable for your purposes.
The schematic for the G7 microphone specifies well filtered 160V operating voltage and 80V (in cardoid position) for the polarization voltage and regulated 6.3V DC for the heater. Where they come from doesn't really matter, as long as the values and the quality are right.
Especially for beginners one should always point out that working with mains voltage and high tube voltages is dangerous for the environment (fire hazard) and life (electric shock).
Professional assistance and qualified testing and final acceptance by an experienced, certified technician are mandatory.
Under that circumstances, I also find the idea of converting an existing power supply to your needs not unattractive. This will save you some headaches and probably cannot be topped in terms of price.
Some examples...
the t.bone PSU Retro Tube II; Ersatznetzteil für Retro Tube II; Schalter für Umschaltung der Richtcharakteristik; 150 / 230V, 50 - 60 Hz; Trageriemen; Anschlüsse: 7-pin XLR Mikrofoneingang, 3-pin XLR Ausgang; Gewicht: 1.72 kg
www.thomann.de
the t.bone PSU SCT 2000, Ersatznetzteil für SCT2000 Mikrofon
www.thomann.de
Just my 2€ cents, stay safe and have fun. Good luck!
