Hi GroupDIY,
Hi Gustav,
Hi Jimmy5K,
welcome to the forum.
I built this kit and put it into an enclosure.
I followed the assembly guide and the universal wiring guide.
I used the 2x18v trafo here:
https://pcbgrinder.com/index.php?route=product/product&path=94_97&product_id=103
I am trying to measure the PSU voltages before I solder the 0 ohm resistors in place.
O.K.
I am getting 22.05V AC between the secondary CT and one end.
At the +18V test point I get +16.72V DC
At the -18V test point I get -16.72V DC
Is the 22.05V AC normal on the output of an 18V trafo?
Yes,ac voltages on transformers differ as long the secondaries are unloaded,some more,some less,but always higher than specified.
Is 16.72V a normal range for the 18V test point?
Not exactly but well in the range you´re after.If you want it spot-on you might have to change the setting resistors on the regulators,e.g. with a 25-gang trimpot or so.But since both positive and negative voltages are even perfectly balanced you´re good to go and fire it up.
NE5532s and Co. are normally driven at +/-15 to +/- 18 vdc anyway.
I am currently using a 400mA fuse.
Is there a suggested way to calculate which fuse to use?
Looks to be a bit on the high side but will work.You can do a current measurement once fired up and start from there.In most cases I use 315mAs fuses on 30VA transformers.
Thanks very much for any help anyone can provide.
kind regards,
Jimmy5K
