..and if it's intermittent, wiggle around components one at a time until you find the one with bad soldering/broken pcb trace...
Jakob E.
Jakob E.
Dontiki said:Hi everyone,
I just finished build this great project but i have some problems.
I have no sound on the output,the signal seems to pass through the unit,and in gr vu mode the compressor acting, but nothing in the input mode of the vu meter.
I read 16.67 + and - v but after 20 second or more ,the vu meter starts to peak in the red all the time,
So i mesure the voltage the positive stay good but the negative oscillate from-16v to -0v.
Also without anything connect in or out.
Don
Would be good to start with the supply voltages, I guess.
Would you mind sharing a picture of the solder work?
Gustav
Looking at the schematic, there is no NE5534 on pcb. All seem to be different pinout dual opamps, NE5532 and TL072.Dontiki said:... seems to stop at the NE5534 (i try different ones) of the...
Dontiki said:You're right
I totally don't pay attention to that point
I use the new revision of the unit all ic's are NE5532 except in the output section (ne5534) and the meter section (TL071)
so i use this schematics https://pcbgrinder.com/download/Hand-of-Light/Hand_of_Light_Schem.pdf
Thanks for your help
Swap IC 3b for a TL072 when you get the unit working (not the cause of your problem, but an improvement)
Remember to add the resistor mentioned in the errata (also not the cause of your problem.
- I would not say voltages are good the way your negative voltage is acting.
- I would start with cutting the jumpers to the supply, check it on its own. If that checks out, try without any ICs inserted.
Did you post a picture of your build?
Gustav
Dontiki said:Swap IC 3b for a TL072 when you get the unit working (not the cause of your problem, but an improvement)
Gustav
Hi ,
I already tried to disconnect the psu from the circuit and that works without the problem.
I add the 22k of the errata and i just check without any ic's and the problem stay the same after
few seconds for the negative voltage.
I add the picture of my first post below.
Thanks Don
Dontiki said:Hi Thanks for all the tips
I just try to put a heatsink on the LM337 and the problem dissapear,but he is getting hot,don't think it's normal .
I gonna try to change it and see what it does,and wait to try if i get sound with the ne5534 in place.
Don
I am not used to it getting hot in this build, wouldn't expect it to. Did you check any of the items I posted? Like the soldering around the LM337.
Whats your power trafo?
Gustav
Dontiki said:I am not used to it getting hot in this build, wouldn't expect it to. Did you check any of the items I posted? Like the soldering around the LM337.
Gustav
Yes i check the solder and continuity with a multimeter between components around with the schematic,i have to check again the small front panel connections.
My power transformer is a Talema 2 x 18v but 50 VA cause i already have it in stock , maybe that can be a problem ?
Don
ophes said:I am been building a HOL of my own, and initial testing is just around the corner. Yesterday I noticed that there is no "Bypass"-switch for the unit. I might be mistaken though (maybe the meter-switch doubles as a bypass?). My makeshift way of putting one in would be to make a "true bypass" switch (like the ones you find on guitar effects), just do it for both leads of the balanced signal. However, I cant shake the feeling that Im dead wrong and not thinking this through.
frederickalonso said:I'm thinking to remove the transformer in my unit and future build to have less noise.
