SUPERMAGOO
and decided to make the original sidechain-amp but somewhat simplified.
with 6L6gc.
and .... works !!!!!!!!!!!!!!!!!!!
with 6L6gc.
tomelectro said:...I think it was a layout issue...
tomelectro said:I just had a similar problem with a 670 clone that someone brought me to fix. When in moderate to heavy gain reduction, the left side-chain amp would launch into oscillation around 60kHz, which would cause the channel to over-compress, and also cause the right channel to go into gain reduction, even with no signal present on the right. This clone used a printed circuit board for the side-chain amp, and I think it was a layout issue, especially since it happened predominately on the Left channel, and the component layout was completely different between left and right channels. After spending much time playing around with the layout, grounding etc, I finally just threw in the towel and changed the 20pF feedback caps (from plate to grid of the last stage of the side-chain amp) to 47pF, which cleaned it right up. (If my calculations are correct, the 20pF caps were providing a rolloff around 120kHz, the 47pF bringing it down to under 60k).
So if you have a scope, try taking a look at your sidechain signal and see if there's any extra junk floating around on it.
Winston O'Boogie said:tomelectro said:...I think it was a layout issue...
Me too. You have to treat the side chain amp as a Hi-Fi power amplifier in terms of frequency response and stability.
Not too much going on with the signal amp that can mess up so, in a way, even more care needs to taken with the power amp than the signal.
SUPERMAGOO, glad you got the 'MonsterChild' happening, for a while anyway. I'm sure a tidy layout and a good checking of stability with appropriate compensation added will get you up and running. I don't know what your output transformer is but, I'd check around the 6L6 - transformer nodes for weird stuff going on. It's the only place you have any feedback happening so I'd start there. Just as Tom suggested I guess...
tomelectro said:Also, I'd be careful about working from that re-drawn version of the 670 schematic - I've found a few mistakes on it (if that's the same one that's been floating around for awhile. It looks like it).
Do you mean that you now have more high end? I'm guessing you have less compression happening at the top end because you're possibly rolling too much off the side amp.SUPERMAGOO said:I replaced 20p to 120p mica-plate. excellent!
I remove the "wiring cap" without problems.
compresses better and
extends the range
this link is correct schem?
http://atvmagoo.googlepages.com/670_Schematic.pdf
Winston O'Boogie said:Do you mean that you now have more high end? I'm guessing you have less compression happening at the top end because you're possibly rolling too much off the side amp.SUPERMAGOO said:I replaced 20p to 120p mica-plate. excellent!
extends the range
I would do frequency response, square wave tests etc of JUST the power amp. What you want is good response with stability and a bit of headroom but you don't want to roll off too much top. Or maybe you do?
You might only need to go up a bit in value from the 20pF you had in there. Or you might need some other network on the transformer. Could be just a secondary termination or something?
Or, if you're happy, leave it as is.
Cool unit anyway
tomelectro said:this link is correct schem?
Yeah, that looks like a copy of an original. There was a nice clean high-res jpg that used to be around (posted by CJ?) . I don't have a place to post it, but if you want to PM me with your email, I'll pass it along.
Glad you got the sidechain to behave better!
12afael said:at least is the bigger 670 clone I´ve seen.
