Lot's of reading later .. and quite a bit of part ordering later ... my current thinking ...
... following belatedly in the wake of the creators, redesigners and info trailblazers
Decided on UTC A15 600:10K for signal input (an A24 or so if I have to have a higher ratio)
Still trying to decide on a signal output - trying to find one for 10K:600 or 15K:600 at a 5W or so.
An LS series UTC would be nice
but not very likely.
Probably the Edcor 8.6K:600 10W PP out traffo would work here.
Perhaps even a custom one with 10K or higher primary.
Using an Edcor 600:10K 2.5W for the control input, and a Hammond 1645 for the output, as suggested by DaveP.
Hopefully I can get it work with a standard 660 style sidechain with a low enough output impedance.
Thinking about 10W of side chain power.
Still learning and understanding the issues (thanks to those individuals who are awesome contributors!)
So far, I like the choice of 8x 6k4p for the channel, at around 125V and 8mA per tube quiescent.
That keeps my B+ within the 65mA I have available. And heater to 2.4A or so.
Another 135mA of B+ for the sidechain amp and I need 200mA of B+ total.
Another 1.8A or so of heater for a total of 4.2A.
Which means I can use the psu pcb from the Poorman 670 and an Edcor XPWR063-120/240
for a 660 channel. Along with a diode rectified L-C-R filtered unregulated 315V B+ for side chain finals.
Bias voltages and a utility voltage are available as well as the 2 regulated HVs and filtered heater DC.
GR grid biasing scheme as per original 670
GR cathode biasing scheme as per original 670 with the dual balance trimmer.
DC threshold and standard 660 sidechain
So - starting to drill holes now!
Again - thanks to all the great contributors in helping me get to the point where it is feasible to even
entertain the notion of a making myself a version of this
It's going to be real interesting.
